Author Topic: Last Used Files in File menu  (Read 310 times)
« on: June 13, 2021, 20:25:54 pm »
Someone know how to "reset" the list of last used files in the file menu ?
Can't find them in the .config file nor in the Windows registry  ???
Offline airnocker
Re: Last Used Files in File menu
« Reply #1 on: June 13, 2021, 21:47:49 pm »
David, one thing that I know works is this.  If you have the CB app icon in your Task Bar, right click on it and you will sell a much larger list of recent files that were opened by the app, compared to what is shown in CB's File menu drop-down.  While the task bar app's pop-up list is showing, right click on any filename and from it's pop-up menu, click 'Remove from this list".  You can clear out the recent list by doing this on every filename that is listed.
« Last Edit: June 13, 2021, 21:49:27 pm by airnocker »
« Reply #2 on: June 13, 2021, 22:08:47 pm »
Ah yes, good tips ...
Thanks !
edit:
eeh ! no, not working for me  ??? they disapers from the list in the taskbar but are still here in CB file menu ..
« Last Edit: June 13, 2021, 22:18:50 pm by dh42 »
« Reply #3 on: June 14, 2021, 11:25:55 am »
Search on your C: dirve for a file called "mru.dat" , you may find more than one, they can be opened with Notepad.
« Reply #4 on: June 14, 2021, 15:55:18 pm »
Hello Eddy
Fine, this work  ;D
