Author Topic: Script help: Finding and Moving Points , resizing rectangles  (Read 197 times)
Offline jimmer
Re: Script help: Finding and Moving Points , resizing rectangles
« Reply #15 on: July 18, 2021, 13:02:33 pm »
For completeness:
Here is my vbs script for resizing my rectangles
sub main
    dim message as string
    dim ent as Entity
    dim polyrect as PolyRectangle
    app.Clearlog()
        'scan selected entities
        for each ent in view.SelectedEntities
            if (typeof ent is PolyRectangle)
                polyrect = ent
                if (polyrect.Width= 596.0)
                    polyrect.Width= 580.0
                    polyrect.Transform.Translate(8, 0, 0)
                    polyrect.update
                end if
                if (polyrect.Width= 595.0)
                    polyrect.Width= 579.0
                    polyrect.update
                end if
                if (polyrect.Width= 590.0)
                    polyrect.Width= 574.0
                    polyrect.update
                end if
            end if
        next
        View.RefreshView()
end sub
Cambam. Mach3. USB motion controller. 1800x950 ballscrew router, vacuum bed, 3kW spindle.
« Reply #16 on: July 18, 2021, 21:45:22 pm »
The pointlists were disappearing. This time I worked it out (guessed it) myself. I think plist.points = plist2.points establishes equivalence or whatever it's called. So I did the transfer item by item.
Ah yes sorry, we need a new point array instead of using the one attached to plist2, because when we clear() the plist2, we also clear plist array because its the same array for both ...
this statement can solve the problem I think, the plist2 array is cloned, then the clone is linked to plist
plist.Points = plist2.Points.Clone
and in addition, on my previous code it is not at the right place in the loop.
this one sames to works on a multi selection
sub main
    dim ent as Entity
    dim plist as PointList
    dim plist2 as pointlist = new pointlist 'temp pointlist
    dim pt as point3F
    app.Clearlog()
            if (typeof ent is PointList)
                plist = ent
                for each pt in plist.Points
                    if (pt.X > 290.99 and pt.X < 291.01)
                        message="pt.X="+formatnumber(pt.X,4)
                        'msgbox (message,0,"boxtitle")
                        plist2.add(283.0, pt.y, pt.z)
                    else
                        plist2.add(pt)'no change
                    end if
                next
            end if
            plist.points = plist2.points.clone 'clone the point array of plist2 and link the clone  to plist
            plist.update
        next
        view.RefreshView()
end sub
« Last Edit: July 18, 2021, 22:05:39 pm by dh42 »
