I know I've run into this before (and I've tried all remedies I can this of to no avail), but why won't these two open polylines join.
I started with two overlapping poly-rectangles. One of them I converted to be Filleted by half the width. This created the semi-circular rounded ends.
I then drew a horizontal polyline wider that the two and across both overlapping objects mid-way up their height, then with all three objects selected, the rectangle, the filleted rectangle and the horizontal line, I did a break at intersection. I deleted the horizontal line segments, the top of the filleted rectangle and the bottom of the polyline rectangle.
When selecting the two open polylines and doing an Edit >Join they refuse to join. I think I know why (the problem is in the open filleted objected in that it's end-points are not at the beginning and end of the point list.
What is the solution?
Many thanks.
