Author Topic: Interesting Finish Texture  (Read 565 times)
« on: November 24, 2021, 00:05:21 am »
I've been wanting to do this for a while.  I've done several simulations, but I finally had a chance to make some molds using it a few weeks ago.  The "arms" are a simple flat surface, but the "body" has a 3D contour.
1.  I used the outline to create a single depth pocket using JK's Trochoidal milling method.
2.  CamBam didn't seem to want to convert it directly to geometry so I created an NC file, and the used that to create an NC MOP.
3.  The NC MOP was easily used to create geometry into an empty layer.
4.  Then I exploded the geometry and used the select by type plugin to delete all the lines.
5.  I mapped all the lines to a surface in a new new empty layer.
6.  Finally I created an engrave MOP to cut the lines onto the surface.  Or rather I used them to cut the finish pass to the surface after leaving some roughing clearance in the preceeding roughing operation.
The mold itself is really nothing special.  Its just a finish texture I have been wanting to do for a while.
Re: Interesting Finish Texture
« Reply #1 on: November 24, 2021, 00:17:49 am »
Neat, Bob!  And nice lures!  Bass will be grabbin' them!
Offline airnocker
« Reply #2 on: November 25, 2021, 01:06:02 am »
For me, one word describes it best...
Wow!
airnocker
« Reply #3 on: November 25, 2021, 13:15:38 pm »
That look great Bob, You sure are cranking out noce work. Very creative.
« Reply #4 on: November 25, 2021, 15:50:36 pm »
Thank you guys. That is a commercial mold that I put up on my website, but what I was doing here was sharing a method of getting an interesting finished set of tool marks on a surface. Many years ago when I was told lazy cam was actually a cam program and not a method of defrauding people out of $75 I was able to make some limited parts with it and one of the things that lazy cam did was a spiral finish pattern. One of the first parts I ever made that I gave to somebody was a little aluminum heart box that I made for my wife and I finished it with a spiral pattern similar to that. It was flat, but at least initially until it oxidized it had a nice spiral pattern that came out from the center.
