Author Topic: 4 axis machining with CamBam V1.0  (Read 41939 times)
« on: April 06, 2022, 14:51:25 pm »
I just finished to translate my 4 axis tutorial to English
Feel free to give feedback if you see some translation quirks ;)
http://www.atelier-des-fougeres.fr/Cambam/Aide_V1/tutorials/Usinage4axes_EN.htm
Re: 4 axis machining with CamBam V1.0
« Reply #1 on: April 06, 2022, 16:04:37 pm »
Lest I miss the opportunity, let me say again how much value you contribute to this group!
« Reply #2 on: April 06, 2022, 17:07:42 pm »
Thanks ;)
« Reply #3 on: April 07, 2022, 00:23:06 am »
To add to Lloyd's comment. Thank you for the work you put into this.
« Reply #4 on: April 07, 2022, 02:23:07 am »
Very good, that must have taken forever.
I did read it through(two cups of coffee).
I only found two things.
spelling 'needed'
1.
We are now going to create the 2D line that will be nedeed
2.
As for a cylinder, where the position of the drawing to be engraved must be at Z = 0 and Stock surface = at the wrapping radius, here, it is the large diameter of the cone which must be at Z = 0, the drawing to be engraved as for him, will therefore be below Z=0.
The highlighted text is not nesseccary in english.
While handy the whole 4th Axis thing has a lot of 'work arounds'.
« Reply #5 on: April 07, 2022, 11:13:26 am »
Thank you very much for the tutorial.
ralfg
« Reply #6 on: April 07, 2022, 13:17:29 pm »
Why do you think is preferable to use the rotation center as Z0 rather than the radius?
« Reply #7 on: April 07, 2022, 13:21:34 pm »
Very nice, thank you for taking the time to make it.
« Reply #8 on: April 07, 2022, 13:46:27 pm »
Because CamBam use the stock surface as rotation radius for wraping and to get stock surface = radius,  Z = 0 must be set at the rotation center. The other advantage is with the driving software, to compensate the feedrade depending of Z position, if Z=0 is at the center, the setting is OK for any diameter but if you use Z = 0 at the surface, you must change the "rotation radius" value(*) for feedrate compensation each time you change the diameter to machine ... and in addition with 4 and 5axis, Z=0 at the center is the norm.
(*) In mach3, it is on the Settings(Alt-6) screen, and because Mach3 have a bug, for Z=0 at the rotation center, instead to write 0 for the rotation radius, you must write a very small value like 0.00001 because if set to 0 the radius compensation feedrate is disabled.
@Dave
Yes sure ! .... months !!! and the arrival of NCnetic helped me a lot to do tons of tests because the result on Mach3 screen is not really clear !  It is a very nice software.
Thanks for the feedback, changes done ;)
« Last Edit: April 07, 2022, 14:03:00 pm by dh42 »
« Reply #9 on: April 07, 2022, 14:47:13 pm »
And it's easier to do the probing on a flat surface like the table of the machine than on the surface of a cylinder, and the table/axis center distance is always the same so we can use an offset to do the Z0, for example, the axis of my A is ALWAYS 76.5mm from the table, independantly of the dimeter to machine, so I just have to probe on the table and to define an offset of 76.5mm to have my 0 in Z.
« Reply #10 on: April 08, 2022, 00:38:32 am »
Because working from center is the accepted standard in the industry.
Offline Tool-n-Around
« Reply #11 on: April 18, 2022, 14:41:45 pm »
That's great David, looks like a lot of work. Thank youso much. I think I have just the project for it. No Mach 3 though but I think I can do it with just positioning and a combination of 2D, 3D, and wrapping. I will revive the post when I get back on it.
https://cambamcnc.com/forum/index.php?topic=9402.msg73431#msg73431
Best,
Kelly
