Author Topic: Random Fillet results CB 1.0 64 bit  (Read 219 times)
Offline ChrisCTS
« on: May 13, 2022, 22:00:50 pm »
I'm having fun trying to fillet some shapes ( polylines ) with CB 1.0 64 bit. I have a fully enclosed  polyline
with 6 corners and only 4 will fillet. I have tried exploding and joining the two which form the left top corner
and tried filleting them, but  they still won't fillet. If I draw two new lines at same angle and similar length elsewhere, I can fillet them no problem.
Is there a known reason why the two top left corners won't fillet. I'm thinking it's a bug.
I have had this before on some other polylines but this is the simplest one that it's failed on.
The left polyline is what I'm trying to fillet, the right in the result I get. (2mm radius )
Chris ???
Re: Random Fillet results CB 1.0 64 bit
« Reply #1 on: May 13, 2022, 22:55:49 pm »
HI Chriss
The line won’t won’t fillet, because it is made up of two polylines and
the fillet can not work because the line is to small (not long enough to fillet).
« Reply #2 on: May 14, 2022, 11:35:58 am »
I don't understand why the entire outline isn't joined to be one polyline.  When I think about 'outlines', my mind automatically goes to single, closed polylines as the definition.
« Reply #3 on: May 14, 2022, 13:23:29 pm »
Lloyd I used the file cleaner to find the problem and that’s the resultant pic to
illustrate the problem.
« Reply #4 on: May 14, 2022, 13:50:28 pm »
Yes and same problem on the left corner, but difficult to see because the points are only spaced about 0.007mm ;)
And you can see that something is wrong because the "number of segments" property show 8 segments instead 6
« Last Edit: May 14, 2022, 13:57:35 pm by dh42 »
Offline ChrisCTS
« Reply #5 on: May 15, 2022, 19:38:36 pm »
Thank you Dave and David,
I have just figured out you can only see these when exploded, and have been thinking that, because it's one joined polyline it must be good. ( can't see the defects when zooming in on the joined polyline ). I will correct my way of thinking and now know how to check when I have an issue like this in the future.
Not sure how I generated this defect in the first place, could this be a result of joining, when there was a small gap?
Your help is very much appreciated.
Chris   ;D
« Reply #6 on: May 15, 2022, 20:17:44 pm »
Yes, probably.
